O.S. LA25 modifications
My Feedback: (17)
So I know there's a few guys out there that know how to wake this little engine up, what are some of the simplest ways to accomplish this?
A old flying buddy of mine gave me back the very first glow engine I bought back in 2004, obviously a LA 25, I took it apart and cleaned it up, i decided to repaint it cause the blue looked pretty tired, the engine it self looks to be in very good shape so I figured I might as well use it.
If I can get a little power out of it that would be sweet.
Good morning, David. That surely is weird. It seems the upside down photos are usually uploaded from an iPhone. I've had it happen to some photos I've uploaded from my iPhone, but usually only the thumbnail is upside down and it doesn't do it every time.
I know admin is working on several forum bugs currently, so I'm sure with time the forum will be working well.
Nice engine
I didnt know they did a red it looks good
Nitro and a slightly smaller prop
is about it
maybe more compression ,
but that is fussy to do ,
lighter planes help a lot
Im running an iron piston 25 tomorrow and just made up a prop driver with brass weight in
down on the counterweight side , to see what happens
Ive got a 9x4 prop
My LA .25 came with 3 head shims .4mm (.015") each. Add to that my engine has a total head spacing of .005" without any shims installed and I find it to have about .035" too much. I suspect this was done by a previous owner, but why so much I don't understand.
Im gonna see if I can equal or best the .25FSR in power and handling. I have a few different carb's of different sizes that will fit and do some other internal mods. Once I have a boost port cut into the case, I'll see how well it runs with a Brat/Bluebird .25 AAC piston/cylinder. The OS and Brat parts are almost identical in size and port layout. Lots of plans for Frankensteining a couple engines - even diesel conversions for some of them.
My Feedback: (17)
was going to try the LA46 carb in it since it has a larger spray bar, might try a homemade tuned pipe as well, just want to have some fun with it.
My Feedback: (17)
is about it
Ive got a 9x4 prop
is about it
Ive got a 9x4 prop
Well done
I forgot you can use that high temp paint that they use for blocks , its a spray
Dont tempt me,,,,,, it looks good , a green would be good
Oh ,,, the head might be a problem , it gets quite hot ???
My Feedback: (17)
It may be a problem, I sprayed the head as lightly as possible so hopefully it won't get to hot, I'll have it on the test stand very soon so I guess will see what happens
Here's some LA25 food for thought. http://www.flyinglines.org/kb.la25rework.html and part II: http://www.flyinglines.org/kb.darkside.html
If you think that Red LA .25 looks cool, check out the "Batman" engine in the above links. They make a mean looking LA25.
To increase scavenging potential of any engine, the ENTIRE path from intake to exhaust, must be tuned and in sync with itself, or you get very little change that doesn't have significantly negative results to go with it, such as tuning or usable range of rpm. The engine is already balanced to it's current configuration of mediocrity.
Not to argue with you, but these engines have no bottleneck in one area that cripples its potential.
If you want to get into engine work, then fine, but for me it's all about matching power plant to airplane. On two and a half pound plane that is pretty clean it will give what most people would consider very good performance absolutely stock.
My Feedback: (17)
the only time I actually ran this very engine was on a small funfly plane that was designed around the use of a AP 15 yellow jacket, the AP is very slow running for a 15 but also very lightweight.
the plane with the LA25 came in at just under 2 pounds, so with the LA25 powering it, it flew like a rocket, please keep in mind that this was my very first glow powered RC plane, everything I flew before this was powered by brushed electric motors with old school low discharge lipolys, so just about anything would have felt like a rocket to me at the time
