Tamiya Leopard 2a6 Build Thread
Old 11-30-2016, 01:09 PM
fizzymike
Smile Tamiya Leopard 2a6 Build Thread
Hi Guys,
Last week I received my Tamiya Leopard and I almost ready to begin the build. Before this I have only owned 2 heng long tanks. I dont have experience with building Tamiya tanks so I figured a thread may be able to help. Ive been searching online for the last week trying to piece together what Im going to do.
At the moment I have the Futaba 4yF transmitter and receiver as well as the acrylics that Im going to use as described in the manual. Unfortunately my set was brand new and is missing the manual and paint design reference as well as the tow cables, decals and whatever else is in that plastic portfolio. I looked to the hobby shop and Tamiya to provide a replacement and hopefully I will get it soon.
Im still trying to decide on an air brush set. After all i've read I still cant decide. I dont want to spend a few hundred dollars on a set for this. I was thinking about getting an Iwata neo CN and Neo compressor or just a Master Airbrush set off amazon. I just want something that gets the job done and has a decent enough gravity dual action sprayer. Any thoughts on this before I buy would be appreciated.
Also I havent decided on a battery. Can someone recommend a great quality battery brand I have no idea. Ive had an rc copter go up in flames before. Im looking for one thats 3000-5000mAh.
Id like to use this thread for tips and questions I have thanks.
ID:	2191822   Click image for larger version
ID:	2191823   Click image for larger version
Old 11-30-2016, 02:39 PM
sollie
sollie's Avatar
congratz on the set . A true machine when built :-)
I bought one used ( well, built and shelfed ) last year. And I took it apart to have a look ,and to install a better track tensioner. I got one from Henntec for the tamiya Leo, so you can adjust it from the outside.
Trust me, once closed up , it takes a while to get down into the belly of it again .
I also invested in a better AB gear to last year, after going the cheaper rute first. That compressor lasted 3 Month before it became so noisy , I could not take it anymore .
I went with a sparmax (TC 610H) Compressor and 2 AB's 0,3 and 0,4 mm . Superhappy with that brand . I spent a little more than calculated , but for laying down paint on 1/16 scale It's nice to have a compressor with a 2,5L tank . So it's not running all the time .
When coming to battery, it's really tight in the turret, even after you spent a weekend on the wire layout, hehe. with a heavy nimh ore nicd , the back of turret can sag a little, so I went to my LHS and got 2 lipos , the smalest in footprint in 2s , with the most mah in them ( sadly not more than 2250) and a small lipo alarm. so yes , not the longest drive time with those, but no problem fitting it in the turret , and no sagin.
Old 11-30-2016, 05:09 PM
Pcomm1.v2
Pcomm1.v2's Avatar
Sollie is correct:
Sorting the interior turret wiring is a task and a half and the heavy tank NiMH Battery once placed in the Leo turret will either warp the turret over time and or cause it to immediately sag to the rear, causing the turret to drag or get hung up on the rear deck.
I like the battery placed in the hull solution, that was the main take away tip from the various rc tank forums, a few years back that I received, before my Leo 2 build. Daryl Turner did this custom one off modification to my Leo 2, unique at the time and above my modeling design and fabrication skill level. It works great for easy battery swaps. You can look at your build instructions and figure out your own direct solution to achieve similar results, if that modification is important to you.
NiMH Battery Recommend:
The DuraTrax 7.2V Onyx 4200mAh NiMH Battery DTXC2061 works for me, "lipos" are not a very good or safe idea in my hands
http://www.ebay.com/itm/NEW-Duratrax-Onyx-NiMH-6-Cell-7-2V-4200mAh-Stick-Battery-Pack-Standard-Plug-DTXC-/322271694700?hash=item4b08e3cf6c:g:A54AAOSw8w1X5nk j
Important Tips; Tamiya Leopard 2A6 RC Radio Selection.
A. Futaba 4YF-2.4 Channel Radio System, not that great with the Leo 2.
If you are NOT installing a Tamiya Battle Unit, using the Tamiya Main Gun Stabilization Unit or accessing the complex stick controlled lighting features on the Leo, a Futaba 4YF-2.4 will still work for basic driving and shooting and work poorly for everything else. The Futaba 4YF 2.4 does need "one" self centering stick upgrade kit. Get the needed Futaba 2.4 stick parts here by calling and placing your order:
Hobby Services
Champaign, IL
217 398 0007
Futaba 4YF-2.4 Self Centering Stick Parts.
1. HSP78901. 1M10A18201. Swing Arm ST-53, QTY 1
2. HSP67450. 8M00F01002. Spring ST-41, QTY 1.
B. Futaba 4YF-FM 4 Channel Ground Radio System, best choice with the Leo 2.
Tamiya USA highly recommends using the Futaba 4YF-FM 4 Channel Ground Radio if you are using all the tanks features and want to achieve trouble free working access to the TBU, Stabilization Unit and the stick controlled lighting. The FM Ground radio does not need a self centering stick kit.
My Leopard 2A6 build brief is here:
http://www.rctankregiment.com/rctank...=2247&start=20
Great fun to build and run, enjoy the process.
John
ID:	2191841   Click image for larger version
Name:	3 Crew_Desert-Leo.jpg
Old 11-30-2016, 08:54 PM
TheBennyB
In my experience the only thing that really needs addressing is the weak plastic suspension arms. Not a must, but much easier to do in the initial build rather than go back, budget permitting.
http://mitosal.com/Leopard2A6.html
Old 11-30-2016, 10:07 PM
Pcomm1.v2
Pcomm1.v2's Avatar
Hi,
Probably not a valid build solution, if you just upgrade the suspension arms and not the address the other more demanding turret issues. Why?
The Tamiya Leopard 2A6 1/16 rc model history is that it was first commissioned to Tamiya as a corporate presentation model project for Krauss-Maffei and others, then brought to market by Tamiya as a consumer kit. While a flagship Tamiya model, it was not initially purpose designed as an IR outdoor fighter, so in that regard the Leo 2 kit falls well short of the durability performance of the Tamiya WWII rc tank kits. If one actually builds and runs the Tamiya Leo 2 as an infrared fighting model or even as an occasionally used shelf queen runner, you will soon discover just how important it is to address the tank battery location; due to the structural damage that can be done to the plastic turret by the heavy tank battery resting inside. Next turret issue; just how easy it is to upset and damage the turret wiring doing battery swap outs and moving the battery to the hull means you to not need to open up the turret anymore, and that is a good thing.
Anyway, I did use the Impact – Mitosal metal suspension arms, because my build goal was to take the model to the next level past presentation model status and turn it into a very cool tough backyard IR runner, hence the various design improvements to help reach that objective.
The model is going on 6 years old now and has held up brilliantly thanks to the application of Daryl Turner's vision, engineering design and fabrication modeling skills.
John
ID:	2191861   Click image for larger version
Old 12-01-2016, 05:09 AM
TheBennyB
I just used a smaller 2S Lipo, fits nicely and don't have to mess with anything in the turret. Still get 30-40 min of run time.
Old 12-01-2016, 06:39 AM
Pcomm1.v2
Pcomm1.v2's Avatar
Good luck with that. Show us with photos Bennie and your Leo 2 solution remains a big risk in an expensive model..."had an rc copter go up in flames before", so your no help to the first poster, if that poster was using a lipo, probably was, just my hunch.
Plus, your solution adds weight to the weak turret floor, which will damage wrap it, a primary known Leo issue.
Anyway, do share with photos when your Leo eventually burns down...
Old 12-01-2016, 06:46 AM
fizzymike
Thanks for the advice, I feel like it would definitely be a good idea to put in a track tensioner. where would you say to buy one from? I see a nice one on RCTank.de
I have not heard of the turret sag so now ill be aware thanks!
Old 12-01-2016, 06:48 AM
fizzymike
Im just worried if the spray gun for master air brush is garbage and if its better to get a better one if it cant do the job. How many cans of nato green do you think I need? I read 7 online somewhere is it really that much?
Old 12-01-2016, 06:51 AM
fizzymike
Originally Posted by Pcomm1.v2
Sollie is correct:
Hobby Services
Champaign, IL
217 398 0007
John
Thanks for the advice! I did hear about the centering stick upgrade, Ill definitely order the parts from hobby services. I would like to install the GBS unit as well, but I heard that it works slowly. Also thanks for the battery, is that standard connector compatible with tamiya connectors?
Old 12-01-2016, 06:55 AM
fizzymike
Is mitosal models site still in operation? Looks rather dated, Ive visited there site in previous years but never bought anything. Also how long did it take to ship when you placed an order with them. I also heard AFV-model makes some great aftermaket parts might give them a try.
Old 12-01-2016, 07:01 AM
fizzymike
Haha actually it was a lipo, I absolutely need to stay clear of those.
Old 12-01-2016, 07:17 AM
fizzymike
I must say i feel a little overwhelmed before i started the thread but now im glad i can ask. does anyone here have experience with afv-model?
Old 12-01-2016, 07:48 AM
TheBennyB
They have great stuff. Just have to be patient with them on communications and delivery time. Also if ordering from them remember to tell them to remove the VAT tax if it's being shipped to the U.S.
Old 12-01-2016, 09:45 AM
ausf
ausf's Avatar
I'm from the school of 'buy once' for any tool I plan to use. Airbrush is doubly so. If you plan on using it, buy quality otherwise you'll be struggling all the way, screwing up your model and time.
No matter what anyone tells you, there is no way any copy of an airbrush is as good as the original and the 'I'll buy cheap and get another in a few years' is ridiculous.
I bought my first Iwata (HP-BC2) in 1986 from the original Pearl Paint in NYC. It's still all original, needle and nozzle and I used it last week and nearly every week over the 30 years. I bought two more over the years for different capacities and the only thing that has changed was the box is no longer wood. And the killer is, they are less expensive since the market is wide open now with the internet. Last one I bought came straight from the Home Islands for $147. My original was well north of $300.
Old 12-01-2016, 10:37 AM
sevoblast
Etoarmor has them in stock in the Maryland warehouse. Here's the link:
http://www.etoarmour.com/product_det...roductID=HT016
Guido Henn builds very high quality idler systems and I use them myself.
Be advised we are in process of upgrading to a new web sight. This event is scheduled to happen this weekend. If you order and do not have a reply within 24 hours please contact me at etoarmor@yahoo.
Old 12-01-2016, 03:56 PM
Pcomm1.v2
Pcomm1.v2's Avatar
Hi,
As Bennie stated, AFV is a great parts source for your Leo 2 build. I got the MG turret carriage and metal turret storage baskets from AFV.
I used Mitosal's Leopard metal adjustable idler system, because Henntech wasn't around during my build and the Mitosal parts work good. I do use the Henntech idler system, sourced from ETO Armor, on a Leo 1A4 build currently on my work bench and that system is excellent.
Just email Mitosal and ask them if they are still selling parts and if whatever is in stock. I also sourced road wheel bearings from Mitosal, but that was several years ago.
"Thanks for the advice! I did hear about the centering stick upgrade, Ill definitely order the parts from hobby services. I would like to install the GBS unit as well, but I heard that it works slowly. Also thanks for the battery, is that standard connector compatible with tamiya connectors?"
Answers:
As to your radio selection, the Futaba 2.4 in my experience, will not operate the Tamiya Leo 2 Stabilization Unit. That fact drove both Daryl Turner and myself crazy for a bit. That is why I later switched out my Futata 2.4 and replaced it with the Futaba FM Ground Radio, per tech advise coming from Tamiya USA. The stabilization unit, TBU and stick light commands then worked perfectly and immediately
The stabilization works well in my model and is not slow, when using the Futaba FM ground radio. The Leo 2A6 DMD Unit is older tech, so that is probably why it is not very compatible with the later to market Futaba 2.4 radio system.
John
Old 12-01-2016, 07:11 PM
sevoblast
Eto has all the Schumo parts for the Leo in stock. The Schumo idler is good but since HennTec came out with their idler system it is out classed but still available. All parts are in the Maryland warehouse.
http://www.etoarmour.com/products.php?ViewCategory=7
Old 12-02-2016, 01:43 PM
Crius
Hey Fizzymike, Paco has been watching this thread but for some reason can't get online at RCU so he asked me to post this link for you. I guess he had the same problems and this was his fix
http://www.rcuniverse.com/forum/rc-t...6-build-5.html
Just in case the links doesn't act right, he says what you need is on page 5.
EDIT: The link takes you to page 5, so scroll down a bit and you'll find Paco's solution to the turret sag. I think it looks like a great idea. Simple, and gets the job done.
Old 12-02-2016, 01:48 PM
Crius
I also swear by Iwata (even though I have no where near Jeff's experience) and I can tell you first hand that Iwata is to airbrushes what SnapOn is to tools. I bought an Iwata HP-CS and it's the only airbrush I ever use anymore. And the triple action handle kit is great, too. If you have a Hobby Lobby near you go to the web for the 40% off coupon and you can get one for about $120.
Old 12-02-2016, 02:25 PM
bowlman
I got my Leo 2 second hand the guy had used all AFV upgrades . I did the battery swap from turret to lower hull . git the metal suspension arms if your going to use it a lot .
Jimmy
Old 12-02-2016, 05:56 PM
TheBennyB
After you soak all this good info in and start your build just remember to take your time and have fun with it. If you come to a step that doens't make sense or something isn't going together they way it should, just put it down and walk away for a bit. You'll appreciate it later
when you don't have to go back and adjust or fix something that you rushed. Plenty of us have built this sucker so ask away on any questions during your build.
Old 12-06-2016, 09:00 AM
fizzymike
Hi,
Answers:
John
Thanks again for the advice John, I wish I knew, I thought it would work since I see everyone using the 4YF. Can you please link to me what radio system I can use? Id appreciate it. I already bought the 4YF but I'm going to see if I can exchange it. I just recently purchased the stabilization unit and I really would like to have that functionality. So you mean both the receiver and transmitter of the 4YF I can't use right? Sorry Im new to this haha.
Old 12-06-2016, 09:02 AM
fizzymike
Thanks! Im going to look into it when I reach that step, I don't want it to scrap right after I put it all together.
Old 12-06-2016, 09:04 AM
fizzymike
Thanks Im most likely going to do those upgrades at a later point in time, I recently purchased a GBS and am trying to get hull reinforcement from tank zone.co.uk but I'm not sure if thats something thats done custom per order and how long it would take to receive.
