DX18 Just Quit
DX18 Just Quit
I was working on a Helicopter setup... everything was fine, turned radio off and it will not turn on again. I checked battery voltage, almost full charge. The charger will not light the light on the radio when plugged in. I did not hear or smell anything burn and it was quiet when it happened.
Is there a fuse the user can change in the back of the radio? I do most radio repairs myself, have done it for years. Just don't want to crack the radio if someone knows there is no fuse to be replaced.
Am I SOL and have to send it in?
I just got off the phone with the guys at Horizon... they had no idea of what this "fix" is. Maybe you could enlighten them, and then I can get the problem resolved. I just don't like the idea of flying this radio at the moment.
You were talking to Support. I said Product Service.
Anyway, I talked to the guys in Service for you and they said it needs to come back. Just follow the process.
http://www.horizonhobby.com/content/...service-center
Andy
Andy
I can't give an official answer, since I don't work over there. There are an awful lot of guys who report that all they have to pay is shipping TO Horizon. Do a little searching around.
Andy
Andy
Andy
Andy
Andy
Now, I have others messaging me to find out what the cause and fix was... your response is to just send it in. I don't like being kept in the dark either.
What is the cause of this problem? I don't know if I can ever trust this radio again... maybe it is time for Futaba.
If I knew the cause, I could suggest a remedy. The guys who would work on it said it needs to come back - my guess is because they need to talk with you while they have it in their hands to see if they can duplicate it. It's impossible to fix something if you can't find the root cause, and a web forum isn't going to do that.
Andy
Andy
Sorry, I disagree completely... an internet forum is exactly the place to talk about these intermittent issues. I cannot duplicate it flying my micro copters. I will be damned to trust it flying a large 800 sized helicopter. What is tech support going to say?... well we can't reproduce it here... and send it back? That is not a solution. The more people are aware, we might run into a lot of people experiencing the problem... Then, you might believe me.
If I say it happened, it happened. I care about a fix, and letting others know there is a problem and not sweeping it under the rug.
It had something to do with replacing the switch. It's only happened to 2 or 3 radios so far - it looks like something they just need to fix as it occurs. Nothing you can do pre-emptively.
Hopefully by now you sent it in and have it back. That was back in last July when you asked about it.
Andy
Andy
My Feedback: (38)
Well, austin jetlag jet rally is this weekend, went to charge my gen 2 dx18 up last night, noticed charging light did not come on, unplugged tried again, no light. Turned transmitter on to check voltage and the transmitter won't power up remove the battery and check voltage and it's at 8.25 volts so the batteries good I guess this is a common problem with these radios
