Bruder Truck Build
its a material that we take off mesh banner material it is a carrier for the mesh banner once the banner is done printing it is removed and is usually thrown out but i have a bunch of it send me a PM i will send you some to try out if you want i'm sure you will like it
Greg
Greg
Greg, Thanks for the offer but I don't have any plans to do anything that will need a tarp any time soon. I usually use aluminum foil or an old worn out handkerchief. After those go through the washer and dryer a few hundred times, all of the fuzzy material is gone and acrylic paint, strong coffee or shoe dye works pretty good if I do it right.
rex
rex
rex
rex
you can use it to make rolled up tarps also like on my Pershing
[ATTACH]2170117[/IMG]
[ATTACH]2170118[/IMG]
[ATTACH]2170119[/IMG]
cool truck Rex i hope mine will look ok when it's done have to figure out a drive train and hope this stearing i have on it now will be ok
With the skills you have, why not get a 1:35 scale model of the truck you want to build, and then just buy the 3D printed wheels for it from shapeways. There is a guy that has really nice rims and tires for all the popular US trucks from WWII.
I want a CCKW and have been thinking about doing this. Firing up my casting bench has also crossed my mind too but I really don't have time to do that much these days.
Tamiya model
I ordered the Tamiya CCKW through Amazon about 6 weeks ago to get a feel for the structure. It took about a month to come from Japan. I plan on using 1/16 inch metal for a basic frame and doing the rest from plastic since the real trucks used flat metal pieces for most of the parts. Still thinking about the leaf springs since I doubt that I can actually make them work on a 1/16 scale model. The real trucks used separate drive shafts running to each set of real wheels so modified axles from regular RC trucks should work. I am still in the planning stage after thinking about this for two years. I will keep a log on this as I make progress and I will keep an eye on what the pros are doing. jot
