How to Build a B-29
How to Build a B-29
Old 11-13-2015, 07:49 AM
kram
My Feedback: (7)
kram's Avatar
Default How to Build a B-29
Dwayne Fosseen is the Big Cahuna of the Bomber Boys here in central Iowa. This is his 3rd B-29, one might say his FIFTH, and he has built at least that many B-17's and mentored several more. His planes have won and placed at Bomber Field and many other events. His birds have proven their air-worthiness and longevity: I personally own and fly a 120" B-17 he built 29 YEARS ago and a 141" B-29 he built 9 years ago.
If you look carefully in this impromptu photo from his private field, you can see 5 of his planes
NOT man known for being an extrovert or an Internet chatter, he would never post his own build thread, but he has agreed to let me chronicle his most recent project: his third Don Smith B-29. This will be a reversion to his first: a 1/10 scale (the one I now own) the second a 14 ft-er he still flies. Bomber builds usually take him 2 winters, the first mostly devoted to planning and construction, the second mechanical out-fitting and finishing
Hang on to your hats!
Mark Taylor (aka Ambrose Bierce)
Name:	CIA 2011  199.JPG
Old 11-13-2015, 08:15 AM
kram
My Feedback: (7)
kram's Avatar
Old 11-13-2015, 08:19 AM
kram
My Feedback: (7)
kram's Avatar
ID:	2130392   Click image for larger version
ID:	2130393   Click image for larger version
ID:	2130394   Click image for larger version
ID:	2130395   Click image for larger version
ID:	2130396   Click image for larger version
Old 11-13-2015, 08:34 AM
kram
My Feedback: (7)
kram's Avatar
Dwayne's Comments:
Kit cutter did a pretty good job and the wood is perfect; PRECISION CUT KITS
I plan to do the hardest part first (the wing) and the rest will be less of a problem
I plan to put a servo in each engine and use the new Futaba 4-engine control program
(previous Dwayne bombers have a single giant servo in center wing driving 4 cables to the throttles)
Old 11-13-2015, 08:38 AM
kram
My Feedback: (7)
kram's Avatar
Glue wing to table with scrap wood scraps with main bottom spar straight and hold washout exact with wing glued to table.
Glue enough scrap pieces to hold solid.
Sanding, TE, aileron and some flap area work will be completed with wing glued to table
Old 11-13-2015, 08:40 AM
kram
My Feedback: (7)
kram's Avatar
WASHOUT:
Center of wing Zero degrees
Plug-in wing joint 1.75 degrees
Wing tip 3.0 degrees washout
Old 11-13-2015, 08:46 AM
kram
My Feedback: (7)
kram's Avatar
Now I will be working the left wing TE: has to come out straight from tip to root with 3.0 deg washout
Flap and aileron have to twist with the washout while being built
Sheeting has to lie flat on a frame that is sanded and positioned with the washout
Top sheeting will somewhat hold the twist and the bottom sheeting locks the washout solid
Old 11-13-2015, 08:48 AM
kram
My Feedback: (7)
kram's Avatar
Mark's Notes:
Pay VERY close attention to Dwayne's washout and wing-building notes. They are why his planes fly well at low speed and win awards and last many years
Old 11-13-2015, 11:38 AM
Warbird Man
My Feedback: (95)
Warbird Man's Avatar
Gotta love bombers !
I see you mentioned using a new 4 engine control system. I also have mine set up to use a separate servo for each engine. Are you talking about Futabas MSA -10 synchronizer or is this a program in the radio TX?
Old 11-13-2015, 03:50 PM
kram
My Feedback: (7)
kram's Avatar
Futaba 14MZ transmitter
Dwayne still uses 72 MHz. Pretty safe these days, I reckon!
Old 11-14-2015, 07:40 AM
kram
My Feedback: (7)
kram's Avatar
TE string system
I increased the total washout to 3 degrees after measuring the 1/48 Monogram model as 4 degrees (+4 at the root, 0 at the tip)
Stab and top of fuse are the "Zero Reference Points"
ID:	2130563   Click image for larger version
ID:	2130564   Click image for larger version
Old 11-14-2015, 07:47 AM
kram
My Feedback: (7)
kram's Avatar
2-3/8" holes cut for air tanks on both sides
1" holes cut for servo wires, tubes, etc
ID:	2130566   Click image for larger version
ID:	2130567   Click image for larger version
Old 11-14-2015, 07:51 AM
kram
My Feedback: (7)
kram's Avatar
Thin Ca 1/8 strip to hold upper flap/wing pocket
ID:	2130569   Click image for larger version
Old 11-15-2015, 08:13 AM
kram
My Feedback: (7)
kram's Avatar
Supports are added until top wing sheeting is glued
Old 11-15-2015, 04:07 PM
kram
My Feedback: (7)
kram's Avatar
Made a couple new spar braces with a little less dihedral than scale
Wing joiners test fit
Bottom dihedral brace needed replacement with less dihedral brace (top)
ID:	2130815   Click image for larger version
ID:	2130816   Click image for larger version
Old 11-16-2015, 04:56 PM
Mopaerial
Kram. Sent you a pm.
Old 11-16-2015, 07:54 PM
kram
My Feedback: (7)
kram's Avatar
Made spar bridge using two 1/4" aircraft ply on each side of the top and bottom spar
This spar bridge is a critical support for the wing where the wheel wells have to be cut out
Between upper and lower spars, install 3/8" balsa sandwiched between 1/4" ply spar bridges
Exact position to be determined by main wheel size and retracted position. I am building mine for 4.5" wheels
ID:	2131004   Click image for larger version
ID:	2131005   Click image for larger version
ID:	2131006   Click image for larger version
ID:	2131007   Click image for larger version
Old 11-17-2015, 08:08 PM
kram
My Feedback: (7)
kram's Avatar
What I like about this system is it makes the wing tips rock-solid with the center section
Old 11-24-2015, 08:47 PM
kram
My Feedback: (7)
kram's Avatar
Inboard aileron hinge
Push bushing through hinge bracket, then use thin CA to secure bushing
Be sure piano wire will go through straight before CA
ID:	2132383   Click image for larger version
ID:	2132384   Click image for larger version
Old 11-24-2015, 08:51 PM
kram
My Feedback: (7)
kram's Avatar
Use sharp blade to cut bushing flush with lite ply
Add 1/64" spacer, then aileron end cap to give clearance after 1/64" spacer is removed
ID:	2132386   Click image for larger version
Old 11-24-2015, 08:55 PM
kram
My Feedback: (7)
kram's Avatar
GoldNRod #517 yellow makes great bushing
Piano wire .092 fits ID inside yellow. Drill bit .232 makes good fit OD of yellow bushing
Old 11-24-2015, 08:58 PM
kram
My Feedback: (7)
kram's Avatar
Inboard aileron hinge sandwich with light ply and 1/4" balsa between light ply caps with bushings
ID:	2132389   Click image for larger version
Old 11-24-2015, 09:02 PM
kram
My Feedback: (7)
kram's Avatar
Hinge will look like scale 1/48 Monogram when completed with 3/32" balsa sheeting
Second is a photograph from a previous finished model
ID:	2132391   Click image for larger version
Old 11-25-2015, 06:49 PM
foodstick
foodstick's Avatar
So is this online reporter thing going to lead to a youtube channel and film contract?
Haven't seen you online in awhile kram... Your profile says you haven't posted since 2013? technology at its best.
I could have sworn Dwayne was building a B17....
Old 11-26-2015, 05:13 PM
kram
My Feedback: (7)
kram's Avatar
Foodstick!:
Well, there's an idea! A plane-building reality show!
Should get a minimum of 14 loyal viewers.
Naw, I don't think I'm doing the World a great service, but it seems a disservice to the Field of Human Knowledge that really skilled experienced pro's like Dwayne and Frank are out there building with no one learning from them
Leave it to you to be the only one who picked up on my oblique Bierce reference
I have been lightly active on RCU the last 2-3 years, at least a dozen posts per year, so your electronic tally must be false, somehow
I'm documenting Frank's 1/6 Wingspan build on rcscalebuilder, so that may have diverted some of my attention.
Hope to get that running again soon. As you know, Frank doesn't do much building during flying weather, so this recent round of wintry mix should get him jump-started
