Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Control Lines
Reload this Page >
Crankcase pressure setup Voodoo
Control Lines For all you fly-by-wire fanatics!
Old 04-26-2024, 06:02 PM
jayseas
Default Crankcase pressure setup Voodoo
I know this must be posted before but i can't seem to find it or i just don't understand. When using crankcase pressure off the 36X is there just two lines, 1 line to the pickup tube, and the pressure line off the crankcase to the tank. No other vent line correct. or do i need the vent on the tank for refueling thru the pressure line and cap it off after filling the tank?
thanks
Old 04-26-2024, 11:17 PM
qazimoto
thanks
Yes, you can use just two vents. Firstly the fuel vent in the normal place. The pressure line to the tank can just be a tube into the top inside corner of the tank, or the uniflow breather pipe on that style of tank. Either will work just fine. You could add a filling pipe and seal it off when full, or fill through the pressure pipe and use the fuel vent as an overflow. This would mean pointing the model nose down while filling.
We used to limit the engine pressure nipple hole to .012", using the solder and c/l wire trick to help tuning.
Old 05-03-2024, 10:31 AM
markwesti
markwesti's Avatar
I'm' setting up a McCoy 29 that has a front air intake and needle valve , I would like to use a rear mounted needle valve on it . I read you must use a pressure fuel tank , this engine has no muffler . How can I get crank case pressure to the tank ?
Thanks , Mark .
Old 05-03-2024, 11:06 PM
qazimoto
Thanks , Mark .
A pressure tap in the backplate is probably the easiest method. Du-Bro used to sell a pressure nipple together with a suitable sized drill and a 10-32 tap. Still available less the tap and drill. In the old days we'd run a 1/8" Whitworth (similar to a 5:40 UNC) die down a piece of 1/8" Copper tube and screw a brass nut down the thread. Almost anything will work. Now days you could reinforce the thread in place with JB Weld. Make sure than none of the screw protrudes into the engine internals.
We'd also restrict the inner hole in the nipple to about .012" - .015" for more reliable needling. A few years ago I did this to a K&S nipple with a bit of c/l wire and JG Weld inside the nipple. Fill the nipple, Pierce it with the wire, leave it there till it is semi hard, pull it out. It should leave a hole about .012" or so diameter. In the 1960's we used solder to do much the same. Plumbers solder not electrical works best. Coat the wire with carbon soot first if using the latter. Plumbers solder doesn't solidify instantly. It has a "mushy" phase to it's solidification.
markwesti (05-04-2024)
Old 05-04-2024, 07:34 AM
markwesti
markwesti's Avatar
Thanks again qazimoto , that tells me what I need to know . I'm building a B speed plane . Plans are from the 50's it's called the "All American" . I know it's a C but I'm putting a McCoy 29 in it .I also started with a Harter's B pan .
Mark .
Old 05-04-2024, 01:20 PM
GREG DOE
On some engines the upper left rear cover screw hole goes all the way through to the inside of the crankcase. If your engine has the through hole, replace that screw with a 4/40" nipple.
Old 05-04-2024, 01:49 PM
markwesti
markwesti's Avatar
Thanks Greg , I'll check that out when I take the 29 apart .
